Two Of My Zone Valves Have Rust On Them. Do I Need To Replace Them? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 07:51 AM   #1
two of my zone valves have rust on them. Do I need to replace them?
two of my 5 zone valves have rust on them. I do not see any active dripping and the manual open/close works easily (which means that they're open, right?) What is causing this rust? Should I replace them now before the dead of winter comes? I just bought this place and the boiler seemed to be neglected. My contractor said he can get rebuilt ones for $50 each.
Thanks...
h82diet is offline   Reply With Quote
Old 11-18-2011, 03:21 PM   #2
how
Rewards Points: 1,104
Is the rust just on the outside casing from an external source like
condensation dripping from piping above it? Do you get the heat you want through those zones?
The ability to move the activating zone lever only tells you that the zone motor or linkage is probably not seized. When the thermostat for the zone valve is off, you should feel a smooth, steady resistance to swinging over that zone valve arm. It should return to its starting position on its own.
When the thermostat is "on" the swing arm will move fully from one side to the other and can be slid back and forth with no resistance.
If the water(rust) is coming from inside the zone valve, it should be serviced.
Zone valve motors or the valve activating guts are easily replaced.
I am not sure what your contracter means by rebuilt units.
how is offline   Reply With Quote
Old 11-18-2011, 05:25 PM   #3
there are no pipes above it or condensation. The valve lever moves up and down freely. I'll take a picture of it.
Do they make a programmable stat you can use with zone valves? h82diet HVAC 2 11-19-2011 05:02 AM
"PEX" manifold valves Thurman Plumbing 3 10-30-2010 10:37 PM
3rd zone not working properly MichaelChlopik HVAC 1 10-15-2010 05:59 PM
Boiler one zone call heat but not fire up Ballastar Plumbing 6 02-12-2010 11:17 PM
Boiler heating zone not working properly ssevern HVAC 5 12-19-2009 06:05 PM
