Two Into One Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 06:58 PM   #1
two into one thermostat
I have two thermostats one for AC and one for heat. I purchased a RTH2300B honeywell therm because I was told I could go from two to one. The AC I got to match by letter. The heater part red wire has an x and white wire does not have a label. Instructions says do not use x and not to use unlabeld wire. It is a gas heater. I was told it could be done , What do I do? or how do I do it?
vlc191 is offline   Reply With Quote
Old 10-30-2010, 07:30 PM   #2
HVAC / Plumbing
see if this helps you
http://customer.honeywell.com/techli.../69-2327ES.pdf
kenmac is offline   Reply With Quote
Old 10-30-2010, 07:33 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
Can you post the brand and model of the furnace?
Where does the wiring off the thermostat for the a/c go? To the furnace?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-30-2010, 07:34 PM   #4
HVAC / Plumbing
Glad to see you back plumber 101
Old 10-30-2010, 07:42 PM   #5
Rewards Points: 560
THanks Ken. I needed a break after all the BS from a couple guys here. Hope it stays calm here.
Been busy as all get out, thought I come and take a look.
Hope things are well with you
Old 10-30-2010, 07:56 PM   #6
HVAC / Plumbing
Been busy here as well.It was a hot summer here. Waiting for the cold to hit. I'm sure it will be busy when it does. About 75 here today
connecting a 4 wire SP thermostat to a 2 wire system wiichkin Electrical 4 08-15-2010 01:35 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
