Twinning Furnances At Church - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 12:25 PM   #1
Smile
Twinning furnances at church
Howdy All ! I am helping out at a local church and they have 2 Trane xe90
furnances that have two thermostats. The units are side by side use the same cold air and use the same downflow for out put. I understand they can be twinned to run on one thermo, PS I helped install theses units a few years ago , so I feel i can twin them give the correct part/info. Not to say I'm any kind of HVAC pro. I had a pro do the silver solderin and charging of the coolant lines way back when.
dontini is offline   Reply With Quote
Old 11-07-2013, 03:47 PM   #2
Rewards Points: 154
twinning Kit
What you need is referred to as a twinning Kit. I want to forewarn you though that not all furnaces are twinning capable if hooked to the same ductwork. Check with your local equipment distributor to make sure the furnaces are twinning capable and they will give you pricing for the twinning kits.
Patrick Eubanks is offline   Reply With Quote
Old 11-07-2013, 05:41 PM   #3
An old Tradesmen
Rewards Points: 6,500
Check to see if the furnace control boards have a terminal marked Twinn.
Tags
hvac , twinning
Helping My Church Chicyardman Carpentry 4 07-07-2012 12:13 AM
Door Question: Access Control (Keypad Lock) for Church pbishopp Windows and Doors 3 02-10-2012 04:37 PM
An Adventure into a DIY Church Conversion in MN lisacolin Introductions 7 01-12-2011 09:40 PM
mortar disintegrating in church walls wombosi Building & Construction 1 08-13-2010 12:07 PM
