-   -   Twinning furnances at church (http://www.diychatroom.com/f17/twinning-furnances-church-189923/)
dontini 11-07-2013 12:25 PM
Howdy All ! I am helping out at a local church and they have 2 Trane xe90
furnances that have two thermostats. The units are side by side use the same cold air and use the same downflow for out put. I understand they can be twinned to run on one thermo, PS I helped install theses units a few years ago , so I feel i can twin them give the correct part/info. Not to say I'm any kind of HVAC pro. I had a pro do the silver solderin and charging of the coolant lines way back when.
Patrick Eubanks 11-07-2013 03:47 PM
twinning Kit
What you need is referred to as a twinning Kit. I want to forewarn you though that not all furnaces are twinning capable if hooked to the same ductwork. Check with your local equipment distributor to make sure the furnaces are twinning capable and they will give you pricing for the twinning kits.
beenthere 11-07-2013 05:41 PM
Check to see if the furnace control boards have a terminal marked Twinn.
