Old 12-07-2008, 10:46 PM   #1
Twinned Trane XE80 issues
I have two trane XE80s that are twinned. The secondary one stopped working. Looking at the flashing lights shows that there is no call for heat on the second one. I swapped the control boards so I know that the basic functions work. How can I test to see if the correct voltages are being supplied/applied for the twinning circuits?
pconrad is offline   Reply With Quote
Old 12-08-2008, 04:33 AM   #2
An old Tradesmen
Need a multimeter.
How are they twinned. Which wiring method was used.
Old 12-08-2008, 10:25 AM   #3
They are twinned with the single wire method. (It actually uses two.)
1 wire connects each Twin lead, and the other connects the G lead.
Old 12-08-2008, 12:12 PM   #4
An old Tradesmen
How is the heat controled, if there is no wire hooked to the R???
Without a wire of some kind hooked to teh red, it won't have a heat call.
The twin terminal is to sycronize the blower speeds.
Old 12-08-2008, 12:55 PM   #5
Whoops! They are connected with the Twin and the W lead like the doc in the link shows.
I don't see an isolation transformer in my system.
http://www.trane.com/CPS/uploads/use...8_06172008.pdf
Old 12-08-2008, 01:04 PM   #6
An old Tradesmen
If they are on the same breaker in the box, its not needed.
If they aren't its needed.
Sometimes, a system needs the isolation relay. But the installer doesn't use one. And they work for years. And then just stop working.
You need amultimeter/voltmeter, to see what, if any voltage is at the W terminal, of the working and non working unit.
May be that the thermostat can't handle the load, anymore.
Old 12-09-2008, 09:07 AM   #7
It was much simpler than that. While checking voltages, I found a broken wire. Once that was repaired, the system came back to life.
Thank you for your time.
Old 12-09-2008, 12:26 PM   #8
An old Tradesmen
Your welcome.
Meters, they save a lot of duessing.
Trane XE80 not(?) hot enough rossl56 HVAC 5 11-28-2008 03:34 AM
Trane XE80 (Pressure Switch Indicator Err) cherande HVAC 7 09-25-2008 01:02 AM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
