Turning Vane - HVAC - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 06:20 PM   #1
Turning Vane
Does anybody have experience making / installing a turning vane / scoop / wedge in ducting to improve air flow. I have attached a sketch to demonstrate what I am trying to accomplish.
The sketch is of the supply feeding the overhead duct. Any help/ideas are appreciated. I would also like to do something similar in the supply plenum.
Thanks.
mattorrell is offline   Reply With Quote
Old 02-19-2013, 06:39 PM   #2
hi turning vanes do work use them alot ,,,, in yur case move vane so edge catches the 9 inch round corner so it scoops air
hvac dude is offline   Reply With Quote
Old 02-19-2013, 08:04 PM   #3
Thanks. Any idea where to get these/ make my self / have made? I've been calling hvac shops in the Boston area and they think I'm crazy when I ask.
Old 02-19-2013, 08:12 PM   #4
lol .. we use them all the time in canada ,, actually the eng, specify on some drawings .. i say make it up yurself out of some flat joist liner put a 90degree bend on the sides and notch if needede to get radius ,, screw into place from top n bottom if u can get access
Old 02-19-2013, 08:29 PM   #5
Awesome, thanks! By joist liner I assume you mean sheet metal?
Old 02-19-2013, 08:31 PM   #6
yes thats correct just flat sheet metal , let me know how ya make out or if u have any more questions
Old 02-19-2013, 08:53 PM   #7
Thank you!
Old 02-20-2013, 10:26 AM   #8
Rewards Points: 79
What is the main purpose of the turning vane? Air flow or noise?
quincy is offline   Reply With Quote
Old 02-20-2013, 10:28 AM   #9
airflow
The Following User Says Thank You to mattorrell For This Useful Post:
quincy (02-20-2013)
Old 02-20-2013, 06:48 PM   #10
An old Tradesmen
Rewards Points: 6,464
What you drew is not a turning vane. A turning vane would not be the full length/height of the duct like you have it. What you have drawn will help though, but turning vanes would help more.
http://www.aero-dyne.net/
House Valve (Gate Valve) Not Turning Off pvryderz Plumbing 7 10-24-2012 09:19 PM
Delay when turning on light switch Kalquaro Electrical 10 05-02-2012 01:27 AM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 05:47 PM
Pluming Hot Water Turning Cold - Help! kissiffer4 Off Topic 1 01-14-2010 06:00 PM
turning off water Jack Hass Plumbing 1 02-03-2007 10:00 PM
