Turning Down Furnace Burners? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-03-2007, 09:39 PM   #1
Turning down furnace burners?
Hi All.
I have a Carrier furnace, 1985, model #58SSB080-BC. It appears to have an electronic ignition.
I feel like the outlet pressure is too high. It makes quite a roar when it comes on and my heating bills are $200 per month. I feel like there is a lot of waste heat going up the flue which is not captured by the heat exchanger.
My question is can the gas pressure be turned down?
The furnace has a valve which allows the inlet and outlet pressure to be adjusted. It has min and max pressures printed on the label. It also has a high and low setting of some sort.
Or, what about restricting the flow via the shutoff valve on the gas line?
Thanks.
Squire is offline   Reply With Quote
Old 11-03-2007, 10:55 PM   #2
Rewards Points: 6,652
Repeat after me "I WILL NOT DO IT MYSELF." After that is said and done, call the furnace guy.
Old 11-03-2007, 11:14 PM   #3
I did some reading on the Carrier webpage and it looks like only a small adjustment can be made with the valve screws. Larger adjustments would require burners with a smaller orifice.
Could you be more specific about what the issues are here? I'm a mechanical engineer so I may be able to understand. Just trying to be educated on the topic before I call in the pros.
Thanks.
Old 11-17-2007, 09:53 PM   #4
Be Careful
Adjusting the gas pressure below recommended settings can lead to delayed ignition or incomplete carryover between the burners on startup. This will result in a mild explosion or booming sound coming from the furnace. Another issue you may have is a stack temperature that is not warm enough. Problems caused by this are lack of draft and / or byproducts of combustion condensing to liquid before the gas is exhausted. One byproduct of combustion is a mild form of hydrochloric acid which can lead to premature failure of flue pipe or heat exchanger. I would not recommend adjusting the gas pressure or derating the furnace with orifice change as either can cause a problem.
shortyshvac.com is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Whirlpool Furnace - Burners cycle every 10 to 20 Seconds agtsrbt HVAC 3 02-06-2007 05:39 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
