-   -   Turning down furnace burners? (http://www.diychatroom.com/f17/turning-down-furnace-burners-13018/)
Squire 11-03-2007 08:39 PM
Hi All.
I have a Carrier furnace, 1985, model #58SSB080-BC. It appears to have an electronic ignition.
I feel like the outlet pressure is too high. It makes quite a roar when it comes on and my heating bills are $200 per month. I feel like there is a lot of waste heat going up the flue which is not captured by the heat exchanger.
My question is can the gas pressure be turned down?
The furnace has a valve which allows the inlet and outlet pressure to be adjusted. It has min and max pressures printed on the label. It also has a high and low setting of some sort.
Or, what about restricting the flow via the shutoff valve on the gas line?
Thanks.
gregzoll 11-03-2007 09:55 PM
Repeat after me "I WILL NOT DO IT MYSELF." After that is said and done, call the furnace guy.
Squire 11-03-2007 10:14 PM
I did some reading on the Carrier webpage and it looks like only a small adjustment can be made with the valve screws. Larger adjustments would require burners with a smaller orifice.
Could you be more specific about what the issues are here? I'm a mechanical engineer so I may be able to understand. Just trying to be educated on the topic before I call in the pros.
Thanks.
shortyshvac.com 11-17-2007 08:53 PM
Be Careful
Adjusting the gas pressure below recommended settings can lead to delayed ignition or incomplete carryover between the burners on startup. This will result in a mild explosion or booming sound coming from the furnace. Another issue you may have is a stack temperature that is not warm enough. Problems caused by this are lack of draft and / or byproducts of combustion condensing to liquid before the gas is exhausted. One byproduct of combustion is a mild form of hydrochloric acid which can lead to premature failure of flue pipe or heat exchanger. I would not recommend adjusting the gas pressure or derating the furnace with orifice change as either can cause a problem.
