Turn Off Unused Radiators? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-12-2010, 05:14 PM   #1
Question
Turn off unused radiators?
I live in a old building with a large storefront with upper/lower appts on one side of the building. The heating system is oil fired steam boiler with only 2 radiators in my living area of roughly 1,200 sq ft. The storefront has 2 radiators and the apts have 5 each of various sizes. As you could imagine there is not much heat in my area and the largest area is supplimented by electric base heat. The oil bill for the boiler (with tstat set @ 68 in the bedroom) is roughly $1,000.00 a month.
The apts are vacant and I was wondering if it were possible to turn off some of the radiators on that side without adverse effects to the entire system, and would this help to direct more heat to my side and possibly cut back oil consumption?
E.N.
flatlander745 is offline   Reply With Quote
Old 01-12-2010, 05:30 PM   #2
Where do you live ?
How far below freezing does it normally get there ?
Are the areas insulated ?
If heat goes from lower Apts to upper Apts thru floor you maybe able to shut down the upper Apts
Does each Apt have a thermostat ?
Are there seperate zones for heat ?
Old 01-12-2010, 05:38 PM   #3
Dave,
I am in eastern PA, with temps averaging 15-25 degrees. No insulation, 1800's baloon framing and heat does rise from 1-2 through open stairwell. The entire system runs on my thermostat.
Old 01-12-2010, 05:57 PM   #4
One thermostat makes it harder...can't turn it down
What type of radiatiors ? Slant fin, old style tall cast iron ?
Do you know if it is a one pipe or two pipe system ?
Problem without insulation & Temp drops you could freeze a pipe
Then any costs savings is wiped out by repairs & damages
You could try shutting 2nd floor partially off & monitor Temps
As long as it stays warm close them off a little more
Not sure why the Apts are vacant but you might consider short term lower cost rentals just to pay for the heating
Old 01-12-2010, 06:25 PM   #5
The building sat idle for five years and the apts are in need rennovation. The radiators are cast iron with a return t-off from the main feed about a foot from the radiators....not sure if they all have it. I have heard about problems with turning off radiators and downstream or upstream issues??
Old 01-12-2010, 07:48 PM   #6
An old Tradesmen
Rewards Points: 8,154
If you have water in the normal plumbing pipes in those apartments. Then you would risk freezing those pipes.
If its a 2 pipe system. You can throttle back the supply valve to those rads. maybe 1/2 way at the MOST.
Old 01-12-2010, 09:11 PM   #7
No H20 is on for plumbing now. I was just thinking of 2 or 3 radiators out of the 5 on each floor if it would help with fuel cost. This is a steam system btw, and also do the bleeder valves lie in a different location on the rad between water and steam rads...mine are at the top.
Old 01-12-2010, 09:30 PM   #8
An old Tradesmen
Steam has the air vents about 1/3 the way up from the bottom.
And doesn't have bleeder valves.
Hot water has bleeder valves at the top.
Old 01-12-2010, 09:43 PM   #9
Were the lines drained & blown out completely ?
Traps drained & plugged so sewer gases will not come thru ?
Theres a lot more to it then simply shutting the water off
Old 01-12-2010, 09:52 PM   #10
These rads have maid-o-mist's 1/3 from down from the Top.
Re:Dave...I am looking to turn valves off on steam rads.
Old 01-12-2010, 10:01 PM   #11
The issue is that the normal plumbing may freeze if you turn the radiators down too far
They rely on heat from the Apt/area being warm enough to penetrate the walls & keep normal plumbing from freezing
Without insulation & enough heat you would be running a real risk
The building sat idle for 5 years - was the heat off ?
Old 01-12-2010, 10:09 PM   #12
Yes, Heat and H2o was off....and there is no H2o there now to freeze.
Old 01-12-2010, 10:14 PM   #13
Ah...I see...so any pipes that were going to freeze it would have already happened
Old 01-12-2010, 10:38 PM   #14
Most likely, yes. They apts will get rennovations....just wondering if turning off 1/2 of the rads will affect the operation of the boiler and/or save me any $$ from the $1,000.00 per month oil bill this season.
Old 01-12-2010, 11:11 PM   #15
An old Tradesmen
I would restrict them. By air vent if they are adjustable.
You could run into a problem shutting them off by the valves. The boiler may build pressure to quick. And then the vents on your rads will close to soon. And you won't have heat in your apartment.
But it will save you some money.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
shower will not turn off all the way mj42070 Plumbing 5 12-06-2009 01:27 AM
Basement Radiators BrettY HVAC 2 10-29-2009 06:43 PM
Removing old oil boiler and radiators 71Whaler HVAC 4 05-28-2009 07:14 AM
