Old 12-19-2011, 03:57 PM   #1
Turbonics heater in the attic
I have a separate zone in my attic that was installed for future use on my hydronic system. Two 3/4" copper pipes, 1 send & 1 return connected together.
The future is now and I have opted for a Turbonics recessed heater (basically a toe kick in a cabinet). I have no intentions of adding an additional heater. Can I just reduce the 3/4" to 1/2" and put the feed side in and the return side out? I read about monoflow tees but I believe they are only required if I install the unit in series. In my case it will be the only unit on the zone. Is this the case? If it is should I have any other concerns?
Chestersthing is offline   Reply With Quote
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
Attic Insulation tim1218 Insulation 4 09-07-2011 11:18 AM
I would like to relocate the flue for my gas water heater Git HVAC 12 04-23-2008 10:37 PM
