Trying To Wire Honeywell IAQ To Burnham RSM/96 Oil Boiler - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-12-2010, 08:45 PM   #16
Rewards Points: 27
Ok I ran only the red and common wire from the heat pump to power the EIM and reconnected the common to the relay and W (since the heat pump isnt hooked up right now) and changed the setting for only heat and it kicked the boiler on in the test menu.
The old thermostat was wire as:
Thermostat--------Color-------Heat Pump
R/Rc---------------Red-------------R/BK
G-----------------Green----------- G
O/B (W)-----------Orange---------- O
Y-----------------Yellow----------- Y
C-----------------Blue------------- B
E/AUX(W2/Y2)----Black------------ W1/W2
I wired the new thermostat as:
EIM---------------Color-------Heat Pump(4TEE3F31B1000A Trane air handler)
R/Rc/Rh-----------Red-------------R
G-----------------Green---------- G
W----------------Orange--------- O
Y-----------------Yellow--------- Y
C------------------Blue---------- B (also to relay for boiler)
W2----------------Black--------- W1/W2
Dehumd-----------White--------- BK
W3---------------Red------------Relay coil for boiler
Do you know if this would be right? or should other wires be jumpered or unjumpered?
6burgh is offline   Reply With Quote
Old 11-12-2010, 08:51 PM   #17
An old Tradesmen
Rewards Points: 6,148
Does your air handler have electric aux heat in it. If not. Then the boiler can connect to W2.
If it does have electric aux heat, then the boiler is third stage heat. As it wired now.
But the wiring as you have it posted, is correct if you have electric aux heat, and want to use it also.
Old 11-12-2010, 08:55 PM   #18
Rewards Points: 27
yeah it has electric heat. I will be able to use all 3 heats? heat pump/Electric Aux heat/boiler without any other modifications?
Old 11-12-2010, 09:01 PM   #19
An old Tradesmen
Yep.
But. If you lock out the heat pump at some outdoor temp. The electric aux will be first stage, and the boiler will be second stage. Meaning that the electric will be doing most of the heating.
I set up most systems like that. With the electric aux only used for tempering the air during defrost(I don't wire it to the EIM). And bring the boiler on as second stage heat(wire it to W2).
Old 11-12-2010, 09:16 PM   #20
Rewards Points: 27
I am gonna try wiring the heat pump wires backup tomorrow. Do these settings look good?
0165-0
0172-2
0173-0
0174-1
0176-3
0180-0
0190-0
0200-1
0210-0
0220-3
0230-(?)
0240-3
0250-3
0260-3
0310-3
0342-1 (have outdoor sensor hooked up)
0345-1
0346-1
0347-2
0350-35
0360-35
0365-0
0370-1
0372-0
0379-1 (wired from dehumd to BK)
0383-1
Sorry to be a pain in your butt the help is much appreciated!!!!!!!!!
Old 11-12-2010, 09:26 PM   #21
Rewards Points: 27
Yep.
Ok I guess the thermostat isn't what I thought then. So the setting 0346 is what controls this?
I might consider this if it is easy to do? I don't really want to use the electric unless absolutely necessary unless for a short time. I wanted it as a backup for the backup. LOL
Old 11-12-2010, 09:32 PM   #22
An old Tradesmen
You only have 2 aux stages of heat. Your electric strips are 1 stage, and the boiler is the second stage.
You must have selected a 3 heat 2 cool system. You don't have a second stage cool.
Your lock out temps are semi incorrect. 360 should be set to a higher temp then 350 is set to(try 5 degrees higher).
Old 11-12-2010, 09:35 PM   #23
An old Tradesmen
Just switch it to W3, and the boiler to W2 then.
Old 11-13-2010, 07:46 PM   #24
Rewards Points: 27
I finally got a chance to wire up the thermostat again. It seems to be working right for heat now!! Thank you!!
Old 11-13-2010, 07:47 PM   #25
Rewards Points: 27
Will wiring the electric aux heat to W3 on the EIM do this?
Old 11-13-2010, 08:18 PM   #26
An old Tradesmen
That will make it 3rd stage heat. And will bring it on when the IAQ determines that the boiler is at 90% capacity of the homes heat loss. Or if you set the stat 2 degrees higher then room temp. unless you set the aux heat lock outs.
If you want to connect the electric aux to W3. Make sure you use smart recovery(adaptive intelligent) so as not to bring on the electric strips during recovery, more then need be.
Old 11-13-2010, 09:21 PM   #27
Rewards Points: 27
Oh ok, You said you don't wire it to the EIM. Is heat pump made to automatically use the electric heat without any additional wiring for defrost? I assume that means when the outdoor unit gets too cold the electric heat covers till the outside unit is working again?
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 10:56 AM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 09:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 05:21 PM
Burnham boiler T&P gauge Joe F HVAC 7 11-25-2008 07:07 PM
Burnham Boiler Rschrei518 HVAC 16 12-22-2007 09:04 PM
