Trying To Replace Wirsbo DT10 T-Stat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 11:23 PM   #1
trying to Replace Wirsbo DT10 T-Stat
I have an older DT10 thermostat that will only display 'lo' and will not turn the heat off, unless switched off entirely. It is referenced that these thermostats scavenge the 24V power from an inline transformer. What options do I have out there other than ordering a newer WT1 from the US? Is there any t-stat I can get from home depot (or similar) that will wire right up to the existing 2 wires? Thanks, cc
carboncopy is offline   Reply With Quote
Old 11-10-2010, 05:19 AM   #2
An old Tradesmen
Rewards Points: 6,540
T87N, or a T87K should work. Their both power stealing.
The Following User Says Thank You to beenthere For This Useful Post:
carboncopy (11-10-2010)
Old 11-10-2010, 08:08 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
tstat
any heating only tstat will work or a conventional stat with a/c will work too, only wire to r and w
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
Old 11-10-2010, 11:48 PM   #4
hvactech, I ended up replacing it before your reply, but was not overly interested in the 2 beenthere suggested. I found out that as long as it is a 24v thermostat it would work. I believe any of the millivolt thermostats will not work though.
Anyway, I found a nice looking cheap 24v one, and connected it, and working great so far.
Thanks for the help.
cc
Old 11-11-2010, 04:27 AM   #5
An old Tradesmen
Becarefull of using the phrase millivolt thermostat.
There are thermostats that are designed for millivolt systems. A millivolt system, is a powerpile system.
A power stealing thermostat, steals/robs/uses millivolts. And can't be used on a millivolt system.
If you use a millivolt thermostat, on a 24 volt system. The thermostat won't last long. Just a FYI for you and future readers of this thread.
Glad you got it working.
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 03:41 PM
When to replace a furnace? stanlam HVAC 3 07-20-2010 08:21 PM
Replacement Thermostat Problem! Confuserated HVAC 8 03-26-2010 09:17 AM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 08:03 PM
LUX digital stat Trane XE80 intermittant problem rossl56 HVAC 6 12-26-2008 06:53 AM
