Trying To Light All-Pro Propane Heater... - HVAC - DIY Chatroom Home Improvement Forum
Old 10-20-2010, 07:32 AM   #1
the Musigician
DangerMouse's Avatar
Trying to light All-Pro propane heater...
I just got a used All-Pro propane heater. The fan comes on just fine, I can smell some gas, but the piezo sparker does not ignite the flame. Is this the way it should look down inside the tube? I'm not sure where the sparker is supposed to 'spark across' from the tube to metal. I don't see a spark, nor hear it trying. Do I need a new 'sparker' assembly, or am I just too stupid to try to use this? lol
Thanks!
DM
Old 10-20-2010, 12:34 PM   #2
HVAC / Plumbing
DM , I haven't seen a heater like you describe. But, if the small tube? is a pilot. then, I would say the sparker should point toward it & not the burner
kenmac is offline   Reply With Quote
Old 10-20-2010, 01:31 PM   #3
the Musigician
No, it's not a pilot. It's solid, not hollow.
I can get sparks inside, I can smell the gas, it just won't LIGHT!
DM
Old 10-20-2010, 03:22 PM   #4
HVAC / Plumbing
If you have a good spark .maybe gas to air mixture isn't correct. They couldn't get it to work .That's why they got rid of it
Old 10-20-2010, 03:57 PM   #5
An old Tradesmen
Rewards Points: 7,414
Post a pic of the other side.
Old 10-20-2010, 05:17 PM   #6
the Musigician
Dunno what good that will do....but OK!
DM
Trying to light All-Pro propane heater...-inst.jpg   Trying to light All-Pro propane heater...-inst2.jpg
Old 10-20-2010, 05:47 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
The white thingy/flame sensor is in the correct position as the gas/flame comes out the middle and mixes with air from the many holes. That sucker is all rusted up and your ignition spark is weak/too small and jumping in the wrong place. Try take the igniter apart and clean out the rust or buy a new one.
Old 10-20-2010, 05:53 PM   #8
the Musigician
So.... you're saying it SHOULD be near the solid post thing?
DM
Old 10-20-2010, 06:01 PM   #9
the Musigician
Here's a close-up... but if the sparker does not want to co-operate, is there any other way I can ignite this thing safely?
DM
Old 10-20-2010, 06:16 PM   #10
Hvac Pro
yuri's Avatar
The sensor has to sense the flame at it's most stable spot and that is where it comes out. The sparker has to ignite the MIXTURE of gas and air safely so that is why it is near an air hole. No way to ignite it safely but post some B4 and after pics of your forearms so we can know how it turned out.
Kenmac may be right and your gas too air mixture may be improper. Tank manifold/regulator or reg inside the unit may be faulty. Propane is VERY finicky at the best of times. Hope you did not pay too much for it.
The sparker is just above the probe thing and below that sheet metal screw. Looks submerged to me. Maybe it needs to be moved further out past that plate into the gas stream.
Old 10-20-2010, 06:19 PM   #11
HVAC / Plumbing
DM. I found a wiring diagram (not sure if it's for your mod) It shows that the other part is a spark plug. the smaller ceramic part must be flame sensor. Actually, it has 2 diagrams
http://www.portable-heaters.com/manuals/000096-01.pdf
Old 10-20-2010, 06:49 PM   #12
the Musigician
I found that too, but it's not the right one.
DM
Old 10-20-2010, 09:53 PM   #13
Maybe your gas pressure is too low. Is it attached to a small propane tank with a seperate regulator.
Artco is offline   Reply With Quote
Old 10-21-2010, 05:33 AM   #14
the Musigician
small tank, yup.
DM
Old 10-21-2010, 07:54 AM   #15
If you are following the ignition instructions on the data plate it tells you exactly how to start it.
The big red button has to be continually pushed in and out for spark. This heater does not have automatic ignition. If it does not spark when pushing in /letting go and pushing in constantly the igniter is N.G.
With the gas off and the power off you should be able to see the spark while pushing the larger red button in and out.
If you read the instructions it states this unit should be serviced by a qualified factory service rep. These are not the type of heaters you want to be messing with if you don't understand them. It could be fatal!!
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 07:31 AM
Trouble with gas water heater pilot light Hotlantadave Plumbing 1 07-10-2009 09:38 PM
Propane Heater Haflinger Farm HVAC 2 11-11-2008 01:35 PM
Water Heater Pilot Light dankreboot Plumbing 3 09-03-2008 07:46 PM
