Trying To Install New Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 06-30-2010, 08:39 PM   #1
Trying to install new thermostat
I'm completely lost here. Why aren't these things standardized??
Anyway, I don't know my system type. I know my airhandler is a Goodman ARUF.
The current thermostat:
E - Brown
Y - Yellow
O - Orange
W2 - White
R - Red
G - Green
C & B are un-used.
There's a blue wire tucked back into the wall.
The thermostat I'm looking at has:
W, Y, G, B, O, Rc, Rh, and C. The R's are jumpered together.
For this, does W2 just go into the new W? And then I'm missing a slot for the E wire.
And I've still got that mystery blue wire in the wall hole.
Can anyone help out? Or at least point me to figuring out my AC/Heat setup, a tstat that works with it, etc.
Thank you all in advance.
Jeff240sx is offline   Reply With Quote
Old 07-01-2010, 06:24 AM   #2
Sounds like you have a heat pump with back up elements and the new stat isn't compatable.
Old 07-01-2010, 06:50 AM   #3
An old Tradesmen
Rewards Points: 7,802
Post brand and model number of new thermostat.
Old 07-01-2010, 07:32 AM   #4
It's the Lux TS9000TS programmable. A Lux digital is currently hooked up.
Old 07-01-2010, 11:06 AM   #5
An old Tradesmen
That thermostat is not compatible with heat pumps that have aux heat.
The W has to be jumpered to the Y. To make the heat pump run in heat mode. So you would not have aux heat when you need it.
Look for a thermostat that is listed as for use on heat pumps with aux heat.
Thermostat wiring question sob HVAC 11 10-21-2009 10:31 AM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
Thermostat wiring jetmanaz HVAC 1 08-09-2009 07:13 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 09:21 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
