Trying To Finding Building Codes For HVAC - HVAC - DIY Chatroom Home Improvement Forum
Old 09-28-2012, 08:51 AM   #1
Rewards Points: 45
Trying to finding building codes for HVAC
I'm having a new furnace/AC installed in my house in Howard County, MD. I'm trying to find out if the building code for HVAC requires such things as a condensate tray under the furnace, but I can't find any online resources to help me with this. It seems like the building codes have copyrights on them and they can't be posted online - which doesn't seem right if it's required that homeowners follow these codes. Does anyone know where I might find the requirements for HVAC installations? Thanks.
rvmeush is offline   Reply With Quote
Old 09-28-2012, 09:04 AM   #2
You'll have to call the building and safety department in your town and find out which version of the code book they use. From there it's buy the book and spend hours/days looking the info up. They might answer simple questions over the phone though.
Old 09-28-2012, 09:04 AM   #3
Code05's Avatar
Rewards Points: 1,104
Actually the building codes can be viewed legally and free online, but they can be a bear to read through-much easier to just ask your local inspector.
Code05 is offline   Reply With Quote
Old 09-28-2012, 09:08 AM   #4
+1 on calling the building (or plumbing) department.
It is my understanding that each town may use different IBC and IRC codes and on top of that, may add in their own "interpretation" of such code(s).
Good luck
PS. Here is a neat reference page for Maryland (http://www.reedconstructiondata.com/...odes/maryland/)
allthumbsdiy is offline   Reply With Quote
Old 09-28-2012, 04:41 PM   #5
An old Tradesmen
Rewards Points: 6,546
If the furnace is in a basement with a concrete floor and a condensate over flow can't damage any part of the structure, then no secondary pan is required.
Your local code enforcement agency will gladly tell you what is and what isn't required.
Old 09-28-2012, 08:25 PM   #6
Rewards Points: 45
can you provide a pointer to where these codes can be found?
Old 09-29-2012, 12:43 AM   #7
Registered User
Rewards Points: 5,216
Find your State, then the Code: http://www.reedconstructiondata.com/building-codes/
Notice if local amendments apply.
eg. Chapter 10-30 and others, if under the IRC; http://publicecodes.cyberregs.com/ic...2009/index.htm
IBC: http://publicecodes.cyberregs.com/ic...2009/index.htm
Others; Google is your friend.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Code05 (10-01-2012)
Old 09-29-2012, 10:38 AM   #8
Rewards Points: 45
Gary
Thanks Gary, that was very helpful.
building a main and sub panels for 2 remote buildings n175h Electrical 30 12-20-2011 03:09 PM
Why building codes are important. Jim F Off Topic 1 08-18-2011 10:18 AM
Building a storage building / small shop..please step in. J S Machine Building & Construction 35 01-20-2010 01:54 PM
Any specific building codes? genner Electrical 10 04-04-2009 01:30 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
