Trying To Find The SEER/EER Of My Old A/C Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 02-26-2011, 02:33 PM   #1
Trying to find the SEER/EER of my old A/C unit
Trying to find the SEER/EER of my old A/C unit. It is a 2 1/2 ton YORK Model H1DH.
Trying to find out what I have as far ass "efficiency" rating is. It is about 17years old. Hoping some of the HVAC guys here might have access to this information. Surprisingly it doesn't come up in a Google search.
Thanks,
Ed
MisterEd is offline   Reply With Quote
Old 02-26-2011, 02:47 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
1993 it was either 8 or 10 SEER. Probably 8. Compressor valves are worn now and it has lost capacity and efficiency. SEER also depends on what type of A coil/evaporator coil it was matched with. Some Yorks had box coils.
Old 02-26-2011, 05:03 PM   #3
An old Tradesmen
Rewards Points: 6,112
Of course, brand and model numbers would help us help you.
Old 02-26-2011, 05:09 PM   #4
Experienced
Jackofall1's Avatar
Heres what a quick search turned up for me
SEER stands for "Seasonal Energy Efficiency Ratio". The systems purchased today typically range from 10.00 SEER to 18.00 SEER. If you have a home and the current system is 10-15 years old, you may have a system that ranges from 6.0 SEER to 10.00 SEER. Of course at the time it was installed, 10.00 SEER was considered "High Efficiency". Today, with all the focus on conservation and energy savings, that "High Efficiency 10.00 SEER" from 10-15 years ago is growing obsolete.
Old 02-26-2011, 05:32 PM   #5
Ummmmmmmmmmmmmmmmmm Please "carefully" read the original post.
Old 02-26-2011, 05:34 PM   #6
Thanks!
Old 02-26-2011, 09:03 PM   #7
An old Tradesmen
Please carefully post Complete model number of both the outdoor and indoor.
Since the SEER and EER rating is based on both.
Old 02-26-2011, 09:13 PM   #8
Unfortunately the indoor (coil) is pretty much sealed up in our furnace so I can't be much help there but here is a photo of the label on the outdoor unit.
Trying to find the SEER/EER of my old A/C unit-2-26-2011-1-45-49-pm.jpg
Old 02-26-2011, 09:21 PM   #9
An old Tradesmen
The H1DH was a "High" efficiency model line for its time.
It was up to 12 SEER. Yours may or may not be close to that, not knowing what the indoor unit is.
Old 02-27-2011, 08:11 AM   #10
Rewards Points: 1,214
You got to keep snooping until you find it. It has to be there somewhere.
If you want been to give you the SEER. Oh what the heck buy a new one don't matter now after all those years it's not EFF with all the hidden dirt in the evap and condenser and the sloppy valves and pistons your EFF is gone. Only keep it if it runs good without breakdowns. If your looking for SEER buy a new one.
COLDIRON is offline   Reply With Quote
Old 02-27-2011, 08:20 AM   #11
Yes, I am buying a new one as well as a furnace which was why I was curious as to what I HAD vs what I am going to GET.
Old 02-27-2011, 12:18 PM   #12
Guess only 8 to 10
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 11:45 AM
Rheem AC unit compressor issues Ogazami HVAC 2 11-29-2010 06:54 PM
AC Window Unit Size, 10k or 12k? Tuksonrider HVAC 7 06-18-2010 12:35 AM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 03:08 PM
Trying to Find out Age of Trane AC Unit ali_bran HVAC 9 07-20-2009 05:37 AM
