Trunk Line Insulation - HVAC - DIY Chatroom Home Improvement Forum
Old 09-19-2008, 12:27 PM   #1
I am a longer time viewer and first time poster. I have a main trunk line in my crawl space and have some 2'' stryofoam that I was able to get free from work that was used for shipping purpose's. Can I put this around my uninsulated main trunk line in my crawl space and not have a condensation problem insde the trunk line?
Sype is offline   Reply With Quote
Old 09-19-2008, 04:22 PM   #2
1610 CUB's Avatar
Rewards Points: 150
Yes you can, cut it close and seal the edges with cheep latex caulk.
1610 CUB is offline   Reply With Quote
Old 09-20-2008, 09:25 AM   #3
Thanks 1610 Cub. I am thinking liquid nails to attach it to the trunk line and then seal the edges.
Old 09-20-2008, 10:13 AM   #4
1610 CUB's Avatar
Rewards Points: 150
That works for me! Make sure the metal is dry
Old 01-18-2011, 09:44 AM   #5
Question along these same lines..... Main Trunk Duct Insulation in Crawlspace
Hello there,
This was the closest post that I could find in relation to my question and I would love some advice.
I have a very tight crawl that we're getting ready to do a bunch of work on and I am wondering this: Can I use closed cell spray insulation along the entire length of my main trunk supply line in that crawl space to tighten it up, reduce leaks and insulate it. It is currently just your basic sheet metal box style construction. I will be replacing the existing metal rigid duct lines that come off of that with insulated flex ducting.
Thanks for the feedback,
mark
markeyro is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
suction line insulation? Lookin HVAC 8 06-06-2008 04:33 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
