Trunk Line Design In Attic - HVAC - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 09:37 AM   #1
Trunk line design in Attic
Contractor started on HVAC install today and told me best location for trunkline is near apex of roof line in middle of attic, taking up 18" of my precious 111" total attic height. This unit is for downstairs. Attic conversion will be at end of 2012. At this time, a 2nd Unit will be installed for attic itself. Attic is currently not insulated and not vented. Intend to use spray foam at end of the year.
My question: Since the duct will start at this apex and shoot out parallel and next to the uninsulated roof, would it not take on heat in summer and cold in winter, making my AC costs higher? I asked contractor to come up with alternatives but they said this is the best way and that the impact if any will not be noticeable in my bill. Is the contractor correct?
Newbie7 is offline   Reply With Quote
Old 04-30-2012, 03:04 PM   #2
as seen on tv
Rewards Points: 150
If it is designed correctly for an unconditioned space should have little impact on operating cost. There are materials designed for that application
qbert is offline   Reply With Quote
Old 04-30-2012, 05:19 PM   #3
Rewards Points: 1,216
That's the way it's supposed to be installed unless you have a crawlspace or basement. If you do he could install the equipment there and leave the attic alone if your going to complete attic renovations in a couple years.
COLDIRON is offline   Reply With Quote
Old 04-30-2012, 06:24 PM   #4
I'd suggest getting the foam done first. The way you are doing it the duct needs to be insulated because it's an unconditioned space. Once the roof deck is foamed then your attic can be classified as a conditioned space. No sense paying for insulation twice and foaming the roof will be a whole lot easier without duct in the way.
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
replacing entire trunk line BlueBSH HVAC 1 11-15-2010 05:26 PM
New 22' Trunk Line unixb0y HVAC 48 06-18-2010 04:52 AM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
attic ventilation design help Noreaster Roofing/Siding 15 04-30-2008 08:31 PM
