Trunk End Vs. Wye - HVAC - DIY Chatroom Home Improvement Forum
Old 02-04-2010, 07:21 AM   #1
Rewards Points: 280
Trunk End vs. Wye
From all the reading I have done on this subject, the consensus is, having a branch run off the trunk end cap is not good. But what if there are no other branches except the end cap one?
I have an 8" trunk that will supply two 6" branches to floor boots. Instead of having a Wye or Tee for each branch, would it be right to install an 8" x 6" x 6" branch Wye to supply the branch floor boots?
The two floor boots are in roughly the same location, in equally sized rooms, but opposite of each other. The 8" branch Wye will be at the end of the 8" trunk and angle out at a 45 degree angle.
The 8" trunk will have a damper.
http://www.standexadp.com/catproduct...ylename=Branch Wye
Earnie is offline   Reply With Quote
Trunk Line Insulation Sype HVAC 4 01-18-2011 09:44 AM
Help with gas pack trunk sizing justinNC HVAC 3 10-31-2009 08:38 PM
Putting a filter in my cold air trunk? BowDown HVAC 8 09-18-2009 11:16 AM
where to position the main trunk? drewhart HVAC 3 02-12-2009 02:16 PM
Shortening supply trunk? shuship HVAC 46 12-02-2008 10:40 PM
