TrueSteam Humidifying Without Furnace Fan On - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-22-2009, 05:08 PM   #16
An old Tradesmen
Rewards Points: 7,344
Its a temp sensor as I recall, not a solenoid.
They may be grasping at straws.
But, as long as they are coming out.
They should be able to find the problem.
Old 04-22-2009, 05:14 PM   #17
dgbehrends's Avatar
Rewards Points: 150
Send a message via Yahoo to dgbehrends
Here's where I think the explanation I posted falls apart. With only the two wires connecting the TrueSteam to my 8835 board isn't it just an open or closed contact and that is determined by the VisionPro IAQ stat or is there communication that the TrueSteam sends to the 8835 through those two wires that says "HEY, I'm ready to steam, go ahead and start the blower!!"? The TrueSteam is not wired to the furnace board in anyway.
Then one would have to question why the blower comes on right away when the tank is empty.
D in MN
dgbehrends is offline   Reply With Quote
Old 04-22-2009, 05:21 PM   #18
An old Tradesmen
Ah.
Could be a wiring issue.
You need to have a wire from the Truesteam connected to the furnace.
Or, ran back to the w8835 to turn the fan on.
Old 05-07-2009, 08:10 AM   #19
dgbehrends's Avatar
Rewards Points: 150
update
The tech came out and reviewed the wiring. He said it looked correct. Unfortunately we couldn't reproduce the cold tank/delayed fan turn on case. We had a full cold tank (~65 degrees) but the fan came on right away which is what it is supposed to do. Never the less, we took a zone damper out and monitored the output of the truesteam nozzle in the plenum. It took a little over 10 minutes to put out any significant moisture. This puts my mind at ease somewhat knowing that it's unlikely there would be any significant moisture buildup before the blower turns on. I had a model 40360 venmar control tinstalled. It interfaces with my 8835 zone board to control my air exchanger . When I get time I'll test the humidifer again, to see if my old venitlator control caused my blower fan problems, unlikely though.
D in MN
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
