Old 02-04-2010, 11:41 AM   #1
Truesteam Humidifier with High Velocity system?
Hi, I have a 2,000 sqft home with radiant floor heating. I also have a Spacepak mini-duct air conditioning system throughout the home. I am wondering if I can use the mini-duct air handler to distribute humidity from a Truesteam (or similar) humidifier. I'm thinking of mounting the Truesteam remotely and piping to the min-duct main line and having a humidistat kick on the air handler when there is a call for humidity. The air would be room temperature since it's not heated.
It's a vacation home in VT that is kept at 55 degrees most of the time we are not there if that matters. It's a post & beam home with lots of wood floors and I want to minimize wood shrinkage/splitting.
Thanks.
imgarret is offline   Reply With Quote
Which heatings system should I go with? keano016 HVAC 5 12-01-2009 03:53 PM
Replace A coil or whole system? Mercenary HVAC 8 07-23-2009 08:37 AM
Help with STEAM Heat One pipe system johnnysanz3 HVAC 5 02-12-2009 11:10 PM
Questions about high velocity air? imola ghost HVAC 6 12-07-2008 11:11 AM
single-pipe steam heat - psi seems too high! ksg HVAC 3 01-30-2008 05:31 PM
