03-11-2009, 05:26 PM
#1
Truesteam Cleaning
Took the tank apart today, after a month and a half of operation, and noticed some sediment. Not to bad. The coil cleaned extremely easy with a 3M scouring pad. The manual says I could clean the tank in the dishwasher which I plan to do. However, it does not specify whether the sediment screen is dishwasher safe. Can the screen be placed in the dishwasher as well? I am of the opinion that the Truesteam should be cleaned at least monthly in conjunction with replacment of airhandler filter.
03-16-2009, 02:01 PM
#2
Truesteam Cleaning
D in MN
01-31-2010, 06:37 PM
#3
Truesteam Cleaning
Well, it's time for another cleaning. The unit looks like it did the last time I did a cleaning in the pictures above. I can clean the tank itself no problem. The coil is another matter. I bought the special scouring pads for non-stick pans or china dishes, and it did not even make a dent. If I take my fingernail and work at it I can get a piece to flake off. The only way the scale build up is coming off is if it dissolves in something. I've heard vinegar might be an option, but haven't read any posts from people that have actually tried it. Any suggestions or comments are welcome.
Thanks,
-Derick
D in MN
01-31-2010, 07:56 PM
#4
An old Tradesmen
Truesteam Cleaning
Haven't use vinegar on a Truesteam. But I've used it on other steamers. And it works well. Works better it its hot/warm.
Same minerals you get in your coffee maker. how do you clean it?
02-02-2010, 10:07 PM
#5
Truesteam Cleaning
I bought 2 gallons of distilled white vinegar at Target, and got a funny look from the clerk. I'll get around to soaking the heating element in a day or two.
D in MN
02-03-2010, 12:01 AM
#6
An old Tradesmen
Truesteam Cleaning
Thats a lot of vinegar.
It doesn't need to be 100% strength to work.
02-03-2010, 01:58 AM
#7
Truesteam Cleaning
OK. The bottle says it is diluted with water to be 5% acidic.
D in MN
02-03-2010, 04:16 AM
#8
An old Tradesmen
Truesteam Cleaning
FDA requires vinegar to be between 4 and 7% acidic. If its less or more. Its not vinegar.
02-27-2010, 03:29 PM
#9
Truesteam Cleaning
D in MN
03-16-2010, 11:21 PM
#10
Truesteam Cleaning
I opened up the filter that I had on my truesteam for over a year and it looks like it is brand new. I'm not going to change my new filter for a couple of years. They cost $20 a piece.
I finally got the water test done. Here is a picture
Looks like the water is rather hard between 120 and 250. I'll have to review my water softener manual to see if I can adjust it. The alkalinity looks a little worrisome too.
D in MN
03-17-2010, 06:44 AM
#11
An old Tradesmen
Truesteam Cleaning
PH isn't bad, 7.5 is a very weak alkaline or base rating.
11-13-2011, 01:47 AM
#12
Truesteam Cleaning
I was doing my annual vinegar soak of my Truesteam and decided to check out what additional information on cleaning this thing might be available. It looks like Honeywell put out a set of videos for contractors.
Here is the one that does a good job of describing the cleaning procedure.
http://www.forwardthinking.honeywell...ule7/index.htm
While inspecting my Truesteam with the cover off, I noticed that the HVAC person whom installed it put the gasket/insulation that surrounds the tube feeding into the supply duct, on backwards. This left the entire area where the tube feeds into the duct open  I dismounted the truesteam, reversed the gasket/insulation however because it had been up against the tank it had gotten a little crusty and brittle so I used some HVAC tape to seal it up tight.
D in MN
11-18-2011, 02:08 PM
#13
Truesteam Cleaning
I think i screwed up on my first cleaning and used the wrong cleaning technique by not using a non-stick scouring pad. Now I get a 14 blink code (failure to heat element). Anybody know where I can order a new heating element coil or what I should do next?
11-18-2011, 06:55 PM
#14
Truesteam Cleaning
Call the contractor who installed it. Elements are not sold but the wholesale house will swap the whole unit for another one. If you bought on the internet then I believe there is no warranty.
11-19-2011, 11:15 PM
#15
Truesteam Cleaning
Just for the record if you let the element soak in vinegar overnight, you will just need a wet rag to wipe off the minerals. The vinegar makes the minerals very soft and easy to wipe off. Mine looked brand new after it's yearly soak. After watching the maintenance video above I learned there was another area they wanted checked/cleaned every two years. I did that cleaning as well. The hardest part to this is making sure you don't dump the reservoir full of vinegar when reattaching. It would be nice if they could add some sort of filler nozzle so I could just pour the vinegar in.
D in MN
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
