Old 01-01-2009, 09:50 AM   #1
True Steam Humidifier installation?
I want to mount a Honeywell TrueSteam whole house humidifier on my gas heater in our garage, but the ductwork is wrapped with insulation. Do I have to remove the insulation or can I simply cut a whole through it and mount the TS on top of the insulation?
kcrossley2 is offline   Reply With Quote
Old 01-01-2009, 10:14 AM   #2
Hvac Pro
I would remove the insulation and securely mount it to the duct. It is a bit difficult to remove the bottom to service the unit so the tighter to the duct it is the better IMO. Make sure you don't block any ventilation vents on that unit if it has them.
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 09:26 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Aprilaire 400A Humidifier Installation Winchester HVAC 4 12-13-2008 11:57 AM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 09:04 PM
