Troubleshooting LED Code Fix - HVAC - DIY Chatroom Home Improvement Forum
Old 05-11-2010, 09:14 PM   #1
Lightbulb
Troubleshooting LED code fix
I have a Armstrong Air Advantage Furnace: High Efficiency 90+
Recieved a Fault code on the LED light. Code is 3 flashes meaning PRessure Switch open with inducer off.
The fan works when in the cool position, but not on Heat. Could it be the Combustion blower failed?
jetspeed is offline   Reply With Quote
Old 05-12-2010, 02:34 PM   #2
An old Tradesmen
Rewards Points: 7,816
Or a blocked vent/chimney, or a loose hose. etc.
Electrical re-wire to code diy-safely Electrical 8 01-04-2010 03:19 PM
frigidaire oven/range trouble code F1 Pete Sloniker Appliances 0 12-12-2009 07:28 PM
code details for boxes kama Electrical 6 01-30-2009 10:25 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
