Troubleshooting Ignition Control Board And Ignitor - HVAC - DIY Chatroom Home Improvement Forum
Old 12-30-2012, 05:49 PM   #1
Troubleshooting Ignition Control Board and Ignitor
On my ICP HVAC unit, mod# PGF336080K00A1, I am getting gas flow to the burners but no spark at the electrodes. I am assuming that since the gas valve is opening, that means all the limit and rollout switches are working. I also have power coming out of the pressure switch.
It seems that the round spark ignitor module or the ignition control board is inop. The ignitor module, (#1173831 superseded by #1177395) has four wires going to it. Blue from the gas valve input, green to ground, and the remaining black and yellow wires coming from the ignition control board. Since I don't know what voltages I should be reading from the board, I have no idea which component is bad.
I didn't see any other posts on this. Anybody know if there is a past thread on this or what voltages I should be getting? Or, is it common knowledge as to what component is probably bad?
Thanks!
Larry
damnyankee36 is offline   Reply With Quote
Old 12-30-2012, 05:55 PM   #2
HVAC Tech/ Browns Fan
If the gas valve is 100% getting 24 voltage and gas is getting into the burners with no spark. Then need new spark control board
Tator1076 is offline   Reply With Quote
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 23 11-05-2014 01:36 PM
ignition control module or spark ignitor issue? agent86 HVAC 2 12-20-2012 09:03 PM
Changing Control Board Questions -- HSI module and AC wire connection humdinger0102 HVAC 7 11-17-2011 01:16 AM
Bryant 350MAV Furnace Code 31 Failure maq0 HVAC 0 10-10-2011 03:07 AM
Carrier furnace not igniting-bad control board? stick_boy1106 HVAC 4 04-21-2011 07:28 PM
