Troubleshooting Gas Furnace - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-05-2014, 09:16 AM   #31
If you have an iPhone ill FaceTime you so we can get you some heat....
hvac27 is offline   Reply With Quote
Old 03-05-2014, 10:18 AM   #32
It's working!! Heat!! I pushed in the button above the pressure switch, I'll still post a pic of it in a minute, it was tripped. So I want to know why that switch is there and what would trip it. It does have a direct wire from it to the pressure switch and then a wire from it down to the control board. Yes, the pressure switch has the tube behind it to the port.
I think maybe I did something at the thermostat to cause it to trip? Say I set it to 60 degrees. So it heated the room from 60 degrees up to 65 degrees and kicked off like it should. But then say I went over to the tstat and set it to 70 degrees almost immediately after it kicked off. Would something like that cause it to trip/fail?
Jesper is offline   Reply With Quote
Old 03-05-2014, 10:35 AM   #33
It's a temp limit for your flue pipe. Prob had some back draft do to excessive wind, causing that limit to get hot. Good stuff bro! I admire your determination!
Old 03-05-2014, 05:55 PM   #34
Hvac Pro
yuri's Avatar
Rewards Points: 1,112
If you have a negative pressure in your house causing wind to come down the chimney it will trip that fumes spill switch. Usually cause by a wood burning fireplace or powerful kitchen exhaust fan sucking too much air out of the house.
Old 03-05-2014, 08:36 PM   #35
An old Tradesmen
Rewards Points: 6,112
Check your flue/chimney to make sure it is not obstructed.
Old 11-03-2015, 05:22 PM   #36
My furnace went out last night and I thought it might be the igniter since it has failed in the past. I had a spare on hand and so I swapped it out but no luck. The inducer just ran continuously and no glow or blower to be had....
Anyway to make a long story short I found this thread after a few hours searching and it basically saved me hours and likely many $$'s too. It turned out to be the same limit switch (the flue/draft temp limit switch). I cleaned it and reset it and everything seems to be working fine now. I checked all the suggested probable causes for intake or exhaust restrictions and everything seems good. I am going to chalk it up to having run my kitchen fan and bathroom fan at the same time (about 450 cfm total) for quite some time while making a roast chicken yesterday -it was smoking like crazy...
I would however like to eliminate the switch from the equation by replacing it with a new one. In case it trips again in the near future I can know it's not because of an old faulty sensor/switch. Does anyone know how to identify the part? There is only a US Patent number on it. 4349806 Klixon brand. The top of the switch is marked in yellow. My furnace is a Carrier Crusader model: 58SSC075-GC | series 110 and the product number is 58SSC075-C-111GC. I can't seem to find the exact product number online. Is a model number match close enough? Or should I not bother replacing it??
Danbob is offline   Reply With Quote
Old 11-03-2015, 06:45 PM   #37
Hvac Pro
yuri's Avatar
I have never had one fail so I would leave it alone. If you want to then you need to get it from Carrier.
americanhvacparts.com or supplyhouse.com may be able to look it up.
Old 11-03-2015, 06:53 PM   #38
Thanks for the quick reply and advice Yuri. It's good to hear that you have never experienced one failing. I had nothing to gauge with (ie. whether they fail all the time, some of the time, etc.) I think I will take your advice and leave it be. Time will tell and I will avoid all my house exhaust fans running at the same time when it's cold outside!
Old 11-03-2015, 07:08 PM   #39
Hvac Pro
yuri's Avatar
You also should have new CO detectors in your house. If you have a water heater on that chimney it could be dangerous as they have no protection from downdrafts.
Old 11-03-2015, 08:08 PM   #40
Coincidentally I was just thinking about picking up a couple more CO detectors. I only have one right now. (small home - 1K sq.ft.) And I do have a hot water tank on the chimney too. It is an older home with a 'sleeved' brick chimney. Been here 16 years with the same furnace since we got here but put in a new hot water tank and chimney sleeve in the past 5.
I will definitely buy some new CO detectors now. Thank you for all your advice. I really appreciate it.
Old 11-03-2015, 08:23 PM   #41
Rewards Points: 6,738
co alarms offer only minimal protection from life threatening co, not low level long term exposure.
My Backround FIY: I am not in any aspect of the HVAC business now but have formal education + some DIY experience. Theory is not a substitute for experience; neither is "old school" experience an excuse to not understand or practice the theory.
user_12345a is offline   Reply With Quote
Old 11-03-2015, 08:30 PM   #42
good point user_12345a.
Old 11-03-2015, 08:42 PM   #43
what about a detector like this:
http://www.kidde.com/home-safety/en/...arms/kn-cou-b/
Old 11-03-2015, 10:55 PM   #44
Hvac Pro
yuri's Avatar
All CO detectors provide good safety against high exposures to CO like a blocked chimney unless they are over 10 yrs old. If you want better protection to very low levels over a long period of time you have to spend over $75 to get more sensitive units. Senco makes some expensive units and this Kidde one suggested list price is close to $200. Probably sells for $100 so at that price point is a very accurate well calibrated unit. Parent company is United Technologies which along with Honeywell and SIEMENS is one of the biggest companies in the world. Owns Carrier and a bunch of other companies so it should be a good unit.
Tags
58ssc075-gc , carrier , error code 31 , gas furnace
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 03:13 PM
Heil Furnace problem - is is the undersized vent? mpmusicny HVAC 8 11-20-2012 01:47 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 09:04 AM
Place to start troubleshooting a Carrier Furnace realjag HVAC 7 05-07-2009 12:26 PM
