while I'm sitting here freezing, i figured it wouldn't hurt to learn something... anyways enough rambling....
Furnace trouble sofar has been no heat
furnace people came, blamed the thermostat... got a new one, installed it still nothing.
accidently bumped the condensate pump which cause the furnace to turn on and work fine YAY!
worked perfectly for a few days which should mean the thermostat is fine i suppose
3 days later the furnace is not working... turned the fan to ON with the thermostat.. no fan
checked the pump.. the pump pan was full of water, also noticed the outlet it was plugged into was not working...
used an extension cord, plugged the condensate pump into a working outlet, still nothing, pressed the float up slowly a few times and released it.. nothing...
not sure what is broken.. cause it seems to be everything
