Troubleshooting Damper Motors - HVAC - DIY Chatroom Home Improvement Forum
Old 09-14-2013, 07:52 AM   #1
Hey guys, was hoping you can help me.
To start my house has an electric furnace hot air with a York Air Conditioning system, two zones (upstairs and downstairs), and in each zone I have one motorized damper. The damper motors are Invensys (model 0483H0004FA00) and the control panel is a Robertshaw SlimZone Classic. My current problem is that the two dampers damper motors stay close all the time when the LEDs (LED #1 and LED #2) on the control are green (documentation say Damper Open). The LED #12 is flashing too (functioning properly). All seem to work except the dampers staying closed allways.
Have you a solution for me.
Thanks in advance
macou is offline   Reply With Quote
Old 09-14-2013, 09:47 AM   #2
An old Tradesmen
Rewards Points: 6,476
Use a volt meter and see if they are getting 24 volts. If they are its time to replace them.
If not, the zone panel could be worn out.
Tags
hvac control board , hvac help
Utica boiler won't ignite / damper culprit? jkr77 HVAC 9 01-10-2013 09:48 AM
Troubleshooting Damper Motors & Control Panel ARB HVAC 2 12-17-2012 07:46 AM
Advice needed for zone damper repair... texanfan HVAC 4 07-16-2011 09:22 PM
Electrical Problem w/ New AC Blower Motors - High Speed shuts off after 15 Min? Tyndale Electrical 6 07-10-2011 04:58 AM
Trol a Temp MST Damper Motor arthrodoc HVAC 15 12-28-2010 04:55 AM
