-   -   Troubleshooting Buzzing Sound - Induced Draft Motor? (http://www.diychatroom.com/f17/troubleshooting-buzzing-sound-induced-draft-motor-90375/)
eagleiiii 12-24-2010 12:27 PM
Hello,
I need some help diagnosing a buzzing sound coming from my furnace. When the thermostat calls for heat, I hear a buzzing sound when the induced draft motor starts. This sound persists through the entire heating cycle. However, at this point, there are some heating cycles where no buzzing sound is present, typically only making this noise in the morning. Visual observation of the furnace leads me to suspect the induced draft motor is the culprit, as the sound seems to originate there.
I understand it is an expensive part to replace. How can I test to see if it's bad? I have a multi-meter and can test for proper voltage/amperage. But what should I be looking for? If it does need replacement, is it a safe DIY job?
It is a Weatherking/Rheem Acclaim Gas Furnace, model: WGDAG-05EAUER.
Thanks in advance for any help you can offer!
-David
hvaclover 12-24-2010 02:30 PM
Pull the flue pipe off the inducer and look down inside...spin the wheel...might be something stuck in it..bird...small animal
HVAC_NW 12-24-2010 03:37 PM
Originally Posted by eagleiiii (Post 556503)
Hello,
-David
Where are you looking? if you web search, you're quite likely to come across Americanhvacpro, that place is a rip off on just about everything. I replaced a draft inducer on an older Rheem that used a spider type and they were charging $200 for a generic Fasco. I used the part # on the old part and searched around. Got the same exact generic Fasco for $60 on a different site.
The bearing in inducer motor in my Rheem/Ruud actually seized up and inducer stalled causing the centrifugal switch to not activate when it was 18 years old. How old is yours? If you spin the shaft and you feel any drag, grittiness or hear something unusual, the bearings are probably going. I oiled mine and it got me by for two days, but ended up without heat for a week while the new inducer was on my way.
The supply house and contractors work together to protect business for contractors by refusing parts sale to consumers, which is a very strong cultural trait of HVAC trade. When I asked a few HVAC companies to bid to replace draft inducer, they quoted ~$500.
hvaclover 12-24-2010 03:55 PM
The OP has not even investigated a foreign object in the inducer and you are telling them to buy a new inducer. Real good trouble shooter you are.
HA!
First you disdain the hvac industry with your post, then complain you had REAL pros come to your home to bid YOUR furnace, and you have the nerve to use HVAC in you screen name.
make up your mind.
HVAC_NW 12-24-2010 04:37 PM
Originally Posted by hvaclover (Post 556570)
[/b][/i]
HA!
make up your mind.
I didn't tell him to not check foreign objects. That advise was already given, so its assumed he will do that. Quit your b*tching about my user name. I was registered here before you were and my SN is not in violation of TOU. Don't like it? Go have your sausage fest at HVAC Talk.
hvaclover 12-24-2010 04:49 PM
Merry Christmas, NW.
HVAC_NW 12-25-2010 07:10 AM
Happy Holidays, clover
eagleiiii 12-27-2010 10:07 AM
Thanks for your suggestions. I went up again to have another look and was quite happy with what I found. In digging in a little further the noise is coming from a relay which I installed which cuts power from my attic fan when my heater is running. It's an easy replacement and fix.
Next question though... where would you look to purchase a SPDT relay? 25VAC on the coil, and contacts suitable for the 125VAC at 8amps? I'll start on Ebay etc, but curious if you had any favorite vendors for such parts. I got my last one from a local HVAC store, but would love to save a trip out if I can.
Thanks,
-David
yuri 12-27-2010 10:57 AM
Acklands/Grainger, Johnstones
