Troubleshooting AC In New-to-me House - HVAC - DIY Chatroom Home Improvement Forum
Old 06-05-2011, 12:32 PM   #1
troubleshooting AC in new-to-me house
hello all,
i'm trying to get my AC dialed in for my first summer in this house. lately, the ac has been kicking on in the morning and running straight through till sunset. so far i've tried to clean the indoor and outdoor coil and taped up as many air leaks as i could throughout the system. the ducts are all insulated flexible stuff. air coming out of the ducts is about 60-61 degrees. cold line entering the indoor coil is about 58. couple questions:
1) is it possible to kick up the speed of the blower? the furnace is (i think) a goodman unit, about 7-9 years old. the air blowing out the top of of the outside coil doesn't seem as hot as other ones i've felt so i think it's got some more to give.
2) currently, my downstairs air return provides the bulk of the air entering the system. it is at the bottom of a flight of stairs in my hardwood floors. based on some googling i take it that this is epic fail from a design perspective. i have an upstairs return about 6ft up the wall, but i can't even get a piece of paper to hang on it when the system is running. any ideas on how to rebalance the returns so i grab more hot upstairs air instead of sucking it off the floor?
thanks all.
sayitaintso is offline   Reply With Quote
Old 06-05-2011, 01:14 PM   #2
An old Tradesmen
Rewards Points: 6,140
Sounds like you could be slightly low on charge, with that air temp you posted.
Old 06-05-2011, 02:13 PM   #3
probably also worth noting: the compressor unit was replaced in the fall due to theft. the label on the side says r410, while the label on my a coil says r22. i am unsure what the system is filled with.
Old 06-05-2011, 03:18 PM   #4
An old Tradesmen
Could be they didn't change the metering device to one for R410A.
Old 06-05-2011, 03:32 PM   #5
where in the system would that be located?
Old 06-05-2011, 03:35 PM   #6
An old Tradesmen
That would be at the inside coil. Inside of the refrigerant system itself.
Old 06-05-2011, 03:50 PM   #7
based on the trouble i had getting the cover off, i would hazard a guess that they didn't change it. i'll take a look the next time i'm in there to clean the other side of the coil.
any thoughts on blower speed?
Old 06-05-2011, 03:54 PM   #8
An old Tradesmen
The return duct is probably too small in the upstairs. not much you can do unless you run a new duct up there.
Old 06-05-2011, 07:03 PM   #9
AKA HVACTECHFW
Rewards Points: 1,208
if they didnt change the coil, you not only need to be worried about the metering device, but also the coil. IF the coil was not made for the pressures of 410A then they tend to become swiss cheese with holes all over.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-05-2011, 07:25 PM   #10
An old Tradesmen
When the switch to R410A came about. most manufacturers just re pressure tested their R22 coils. The coils held, and they said they are rated for R410A.
Most older R22 evap coils are actually thicker walled then newer coils with only a R410A rating on them.
Old 06-05-2011, 07:28 PM   #11
AKA HVACTECHFW
ive been to quite a few calls where other contractors did just this and found huge multiple leaks in the evap.
IT IS WHAT IT IS
Old 06-05-2011, 08:09 PM   #12
An old Tradesmen
If the coil was already leaking before the switch over. it will make the leaks worse. Seen lots of condensers condemned as leakers when it was the evap coil that was leaking.
Old 06-06-2011, 11:04 AM   #13
so is there anything to be gained by increasing the blower speed? Or am I barking up the wrong tree with that? Should I just reinstall the window unit that was in the loft area when I bought the place?
Old 06-06-2011, 11:03 PM   #14
An old Tradesmen
Speeding up the blower may help slight;y. Or it could just make the registers loud, and cool the down stairs quicker.
There is no harm in trying a higher speed(if it isn't already on its highest speed), and see if it helps. if it does, thats great, if it doesn't. Then put the window unit back in.
My guess, is that the previous owners already tried having the blower speeded up, and it didn't help.
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 08:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
New house drywall DISASTER pharm07 Off Topic 13 03-25-2011 03:24 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
