Old 04-07-2010, 11:48 PM   #1
troubleshoot thermostat 6 wire
trying to help a friend. Someone told him thermostat was bad. He bought stat for 4 or 5 wire and when i pulled old stat down realized it had 6 wires. He says that when set on heat air handler continues to run set temp is reached. I would like to trouble shoot my self. I believe wires on existing stat were labeled g-green, y-yellow. y2-orange, r-red, w-white, w2-black i think. Any ideas?
GR Berger is offline   Reply With Quote
Old 04-08-2010, 12:12 PM   #2
Pro Tech™
Your new thermostat would have to support 2 stage heating and 2 stage cooling. There will most likely be a menu on the thermostat that requires configuring.
Last edited by beenthere; 04-08-2010 at 03:58 PM. Reason: Removed link to another forum
User75130 is offline   Reply With Quote
Old 04-08-2010, 08:44 PM   #3
I replaced old with new thermostat for 2 stage heat and cool. Still have same problem when I called for heat and desired temp was reached it still continued to run so I turned off thermostat and it still stay on. I had to determ R then G and it stopped.Is there a limit or something I can check that might be holding fan on? Maybe a switch thats supposed to open that is not?
Old 04-08-2010, 09:24 PM   #4
An old Tradesmen
Sounds like your thermostat wore may be the problem.
3 wire thermostat shadow82399 HVAC 3 09-20-2009 08:37 PM
Which thermostat and how to wire it! woodworker2 HVAC 1 09-18-2008 09:18 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
X wire on old thermostat Jellybean HVAC 3 03-30-2008 08:14 AM
