Troubleshoot Blower Motor - Lennox - HVAC - DIY Chatroom Home Improvement Forum
Old 12-28-2006, 04:57 PM   #1
I have a Lennox 80UHG-75 furnace that I am replacing the Ignition Control Board (32M88). The furnace was going through normal ignition and everything worked up until the fan motor was to kick on. The 2 LED's indicate no problems. The furnace stays on for a minute or so and then shuts down. I assume there is a delay timer and if the blower fan doest kick on it shuts the furnace down.
I opened the panel and found one of the fan relays burned on the back of the board so obviously it needs to be replaced.
Before I put the new board in is there a good test to determine if the capacitor or motor is the cause of the relay burning up or did it just fail on it's own?
The motor does turn free on it's own so at a minimum I know at this point it is not locked up.
LongShot is offline   Reply With Quote
Old 12-28-2006, 06:35 PM   #2
No need to worry.......relays on printed circut boards fail all the time.....If you have a meter that can check microfareds then you can check the cap, the rating should be printed on the cap.
acefurnacefixer is offline   Reply With Quote
Old 12-29-2006, 06:30 PM   #3
remember if you do replace the blower motor you should also replace the capacitor at the same time.
trollmastergeneral is offline   Reply With Quote
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Heat Pump blower speed? ktkelly HVAC 1 07-18-2007 10:01 PM
Goodman HVAC gmp100-3 Inside blower problems ray_adrea HVAC 4 06-28-2007 12:31 PM
Induction blower seal ktritz HVAC 4 03-05-2007 08:52 PM
Replacement Inducer Blower caseywa HVAC 18 11-27-2006 03:42 PM
