Troubles With My Lennox Diplomat Furnace... - HVAC - DIY Chatroom Home Improvement Forum
Old 02-09-2009, 04:59 PM   #1
Troubles with my Lennox Diplomat furnace...
The heat went on in the furnace last night and I'm a bit confused. It seems like everything is working besides the fan. The pilot is kicking in and the exhust fan is running, but the blower will not come on. I tried the AC and it came on just fine. Same with the fan option from "auto" to "on." Came on no problem. I'm not sure what it could be. Any info or suggestions would be greatly appreciated. Thanks in advance.
djjake24 is offline   Reply With Quote
Old 02-09-2009, 05:22 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,440
Post the model and serial#. Should be inside by the burners.
Old 02-09-2009, 05:24 PM   #3
An old Tradesmen
Rewards Points: 6,548
Could be a bad winding in the motors heating speed tap.
Or, it could be the furnace control boards heating fan speed relay is bad.
Old 02-09-2009, 05:33 PM   #4
Lennox Diplomat
Serial # : 6393E69829
Model # : 80MGF3-75A-1
Old 02-09-2009, 06:39 PM   #5
Hvac Pro
yuri's Avatar
Beenthere is correct.
That unit is 15 yrs old and it looks like the heating fan relay is faulty. The new circuit board is a retrofit and EXTREMELY complicated to change. Not a DIY project. I would call a reputable Lennox dealer. May also be the motor. 90% board, 10% motor. I work on lots of them.
Old 02-10-2009, 07:00 AM   #6
G71
Pro
Agree, those and the G-24. P.I.A.
G71 is offline   Reply With Quote
Old 02-10-2009, 06:23 PM   #7
Hvac Pro
yuri's Avatar
G71. Lennox guy eh? I sell lots of them.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
For all you Lennox owners ibwahooka HVAC 9 11-23-2008 05:06 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
1973 Lennox ES2 Furnace Noisy indygo HVAC 1 03-26-2006 08:43 PM
