Trouble With A Trane - HVAC - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 08:36 PM   #1
trouble with a trane
i have a trane heat pump that is acting weird. works properly in a/c mode but when in heat mode the high and low side pressures are both around 325psi. i talked with trane tech support but no help. any ideas would be appreciated! model #2twb3018a1000ar
dull is offline   Reply With Quote
Old 12-18-2012, 09:56 PM   #2
Rewards Points: 616
both 325 .... not possible.....
carmon is offline   Reply With Quote
Old 12-19-2012, 04:20 AM   #3
An old Tradesmen
Rewards Points: 7,400
Sounds like you took your readings on the service valve schrader fittings. They should be about the same in heat mode then. Need to use the true suction fitting.
Old 12-19-2012, 07:14 AM   #4
i work at an apt complex and we have app. 450 goodman hp's and 2 or 3 tranes, so i'm not familiar with them at all. there are only 2 service valves that i can see- high and low side. i'll look at it again today. thanks
Old 12-19-2012, 11:31 AM   #5
Rewards Points: 156
I had a similar failure on my Trane system last year. It turned out to be the expansion valve on the outdoor unit went out.
Is your unit going into frequent defrosts even when the weather is only moderately cool? Pull the cover off the outdoor unit, and see if the expansion valve is getting frosty. If so, the expansion valve needs replacement. My high side readings were really high, and my low side went really low when this occured
av-geek is offline   Reply With Quote
Old 12-19-2012, 01:04 PM   #6
An old Tradesmen
3rd port will be in the side panel near the RV.
Trane Thermostat Replacement roadbiker255 HVAC 7 07-24-2012 01:29 PM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 02:32 PM
Trane XL1200 trouble victorhobby HVAC 5 06-15-2010 04:47 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 12:59 PM
