Trouble Shooting Gas Valve For Fireplace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-29-2013, 10:07 AM   #1
Trouble shooting Gas Valve for fireplace
I have replaced the pilot assemble and the gas valve (Robertshaw's 710-511) and the polit light now works. What does not work is the gas is not being passed through the valve to be ignited by the pilot flame. Since the pilot is lit, the thermocouple and the thermopile must be working, correct? What could be checked?
1134-3w is offline   Reply With Quote
Old 12-29-2013, 12:56 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,234
all the electrical connections on the gas valve need to be scraped so there is bare metal showing. the connections need to be TIGHT on the valve also. that system uses 750 millivolts = 3/4 of a volt and any poor connection shuts er down. same with the wiring to the thermostat or switch that turns it on/off.
Old 12-29-2013, 01:16 PM   #3
An old Tradesmen
Rewards Points: 7,270
Moved to HVAC forum.
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Totaline thermostat trouble shooting Goldwing93 HVAC 3 07-30-2009 10:35 PM
Ball Valve Trouble krgoks Plumbing 7 12-01-2007 12:29 AM
electrical trouble shooting - how much does it cost? electricpro Electrical 30 09-07-2007 01:26 PM
Arc Fault Trouble Shooting michael byrnes Electrical 4 06-13-2007 04:24 PM
