Trouble Shooting A Carrier 9200 Weathermaker Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-01-2009, 08:39 PM   #1
Trouble Shooting a Carrier 9200 Weathermaker Furnace
I have a Carrier 9200 that is about 9 years old. The last couple of days, it has produced a burning smell through the vents (smells like electrical fire) After trying to self diagnose, this is what appears to be happening. the venting motor goes on for 90 seconds, then burners ignite, then "sometimes" the blower goes on. When it goes on, sometimes it runs fine, other times it shuts off quickly. When it doesn't go on at all I hear a humming as if there is power to the blower motor, but it just doesnt kick in? I took off the guard shield and self spun the "squirrel cage" and that seemed to work? Any suggestions! Has there been any type of recall on this model?
Also, on the venting motor, I hear water swishing. What could this be?
Any help would be welcomed
Joe
JoeDell is offline   Reply With Quote
Old 01-01-2009, 10:56 PM   #2
HvacWiz's Avatar
Rewards Points: 252
No recalls, sounds like you have a blower motor going out. The water you are hearing is probaly the cause of a plugged up condensate trap. remove it and flush it out in the sink.
HvacWiz is offline   Reply With Quote
Old 01-08-2009, 03:42 PM   #3
Troubleshooting
I have a 9200 carrier weather maker furnace. I came home this week and the furnace was not running. However, the house smelled like burnt wires. I turned off the thermostat and tried to restart. When it did restart the furnace ignited and the fan began to blow but shortly went out. The Blower never came on. I changed the starting capacitor and that did not work. So I thought maybe the fan blower blew out so I replaced the blower in the squirrel cage. So when i tried to start the thermostat the furnace seem as though it was going to come on but then it never ignited and a code of 3 -4 came on the led display. What should I do to get my furnace going? Please help
kaydee1985 is offline   Reply With Quote
Old 01-08-2009, 03:53 PM   #4
Did you do as was suggested in post #2????? Sounds like the sensor for the inducer motor is not sensing the combustion chamber pressure. Could be because of the water??
If it's true that you learn from your mistakes- I'm getting one heck of an education
thumbkins is offline   Reply With Quote
Old 01-08-2009, 04:07 PM   #5
I think I put this in the wrong spot
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
HELP! Carrier Weathermaker Infinity Not Working! MaxPierre HVAC 27 01-19-2009 06:30 PM
Problem with Carrier Weathermaker 9200 Chipley HVAC 12 12-16-2008 12:44 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
