Trouble With My Gas Furnance - HVAC - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 01:34 PM   #1
Question
trouble with my gas furnance
I came home from vacation yesterday and my downstairs furnace is not working. I cross the red and white wires on the thermostat but it only kicks it on for about 30 seconds, and it doesn't restart it at all. I thought it was the thermostat but now I think it might be the flame sensor or something called a proving switch. Does anyone have any ideas?
ddurnal is offline   Reply With Quote
Old 10-05-2012, 09:58 PM   #2
Rewards Points: 616
not really.... hope it is fixed...
carmon is offline   Reply With Quote
Old 10-05-2012, 10:03 PM   #3
JJboy's Avatar
Clean the flame sensor.....if the gas valve is opening and the igniter light the gas burners.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-05-2012, 10:06 PM   #4
Furnace has a L.E.D on the control board that will give you a fail code that will match up with the furnaces fault codes... find that and start from there
Nickhvactech is offline   Reply With Quote
Old 10-05-2012, 10:11 PM   #5
how
Rewards Points: 1,104
Always a good idea to check the dates of the post you are responding to!
how is offline   Reply With Quote
Old 10-05-2012, 10:13 PM   #6
Rewards Points: 616
sorry thought it would be funny...i laughed...
The Following User Says Thank You to carmon For This Useful Post:
Nickhvactech (10-05-2012)
Old 10-05-2012, 10:14 PM   #7
Please hold the line, an agent will be with you shortly...
hvac benny is offline   Reply With Quote
Old 10-05-2012, 10:16 PM   #8
ha ha ha ha def funny!
Old 10-06-2012, 02:42 AM   #9
biggles's Avatar
if you have a "proving switch" then you have an induced draft fan motor above the burner section...that should be the first item to run on a heat call..free spin the squirrel
Old 10-06-2012, 04:50 AM   #10
An old Tradesmen
Rewards Points: 7,816
Did anyone take notice that the post date of the starting post is 1-03-2010
I hope he got it working or replaced by now.
Old 10-06-2012, 07:12 PM   #11
Rewards Points: 610
BIGGLES DIDN'T jes'kiddin' biggles..don't get yer shorts in a knot
techpappy is offline   Reply With Quote
Furnance question. diy4life Building & Construction 29 12-01-2009 05:39 PM
Furnance question satz HVAC 8 02-05-2009 07:44 AM
Furnance burner won't stay on. 2007ken HVAC 11 03-03-2008 11:29 PM
