Trouble Goodman GMP075-3 - HVAC - DIY Chatroom Home Improvement Forum
Old 10-03-2009, 11:54 AM   #1
Vilkas's Avatar
Trouble goodman GMP075-3
Fan runs only when thermostat is on. Steps too troubleshoot. Thanks
Vilkas is offline   Reply With Quote
Old 10-03-2009, 12:36 PM   #2
biggles's Avatar
are you going for heating or cooling
Old 10-03-2009, 09:35 PM   #3
Vilkas's Avatar
Heating
Heating
Old 10-04-2009, 01:35 PM   #4
Set t-stat fan to auto, turn on the heat. Follow the wires from the fan motor to the control board. There is one tab labeled as heat and one as cool. With your multi meter set to volts, set one lead on heat and the other lead to neutral. Within 90 seconds, of the flame being established, you should get 120v. If you don't it is likely something is amiss with the board. Likely, hard to say for sure without being on site.
Flashheatingand is offline   Reply With Quote
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 04:52 AM
trouble with a goodman furance tony fehlen Appliances 1 11-08-2007 08:49 AM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
Trouble - Goodman GMP100-3 Rev B cstelter HVAC 1 10-24-2006 01:27 PM
