Triple Wall Pipe For Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2010, 03:46 PM   #1
DMD
Question
Triple wall pipe for furnace
Why would someone put in a triple wall pipe for a gas furnace? Isn't a triple wall pipe meant for wood burners or boilers?
DMD is offline   Reply With Quote
Old 02-17-2010, 03:50 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,088
Post some pics of it.
Old 02-17-2010, 04:09 PM   #3
DMD
Triple Wall Pipe
I tried. It is a dark picture, but you can see the pipe.
Don't know why anyone would use a triple wall for a furnace. Perhaps there are reasons.
Old 02-17-2010, 05:06 PM   #4
Hvac Pro
yuri's Avatar
No picture available. Go to "go advanced" below/with your reply and follow the instructions and post it as a jpeg or use photobucket or imageshack and post a link here. There is no triple wall pipe but it may be running thru a sleeve which is a air gap/fire separation requirement. Have to see it to know better.
Old 02-17-2010, 06:10 PM   #5
An old Tradesmen
Rewards Points: 6,060
May have originally been installed to use oil or wood.
Post pics.
Old 02-17-2010, 08:16 PM   #6
DMD
Triple wall pipe
Hello again,
I did put up the picture and then took it off again. I decided since we have not yet purchased the home, I should not be putting it up.
Once we do, I'll be back.
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
Double wall pipe Captflx HVAC 4 06-09-2009 01:10 PM
shower head pipe snap inside of wall? snosurfa7 Plumbing 3 06-06-2009 10:15 PM
Fixing leaking shower head...turns out pipe coming out of wall is the source plumbingboy9317 Plumbing 5 05-25-2009 02:41 PM
Sound dampening advice needed steel1 General DIY Discussions 10 10-22-2008 02:51 AM
