Triple Fuel AH - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2009, 09:07 PM   #1
Rewards Points: 502
Triple Fuel AH
Is there such a thing as a triple fuel air handler?
Could I get one that has LP and electric along with the HP a coil?
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 02-06-2009, 09:25 PM   #2
nope. None up here.
hvaclover is offline   Reply With Quote
Old 02-07-2009, 04:55 AM   #3
An old Tradesmen
Rewards Points: 8,234
Not a factory set up.
It can, and has been done though.
Old 02-07-2009, 10:05 AM   #4
JohnH1's Avatar
Originally Posted by hvaclover View Post
nope. None up here.
HAHAHAHAHAHAHAHAHAHAHAHAHHAHAHAHAHAHAHAHAHAHAHA That kills me.
JohnH1 is offline   Reply With Quote
Old 02-08-2009, 12:56 AM   #5
Rewards Points: 502
I was just curious. I had never heard of one either.
-Andrew
DIY hobbiest
Old 02-08-2009, 07:15 AM   #6
An old Tradesmen
Not to get too far off topic.
Andrew, does your monitoring system, have the ability, to record/monitor the temp difference across the indoor coil only.
During defrost cycles.
Old 02-11-2009, 10:28 PM   #7
Rewards Points: 502
Are you referring to suction/liquid line temps?
I have a probe on the suction line right before it splits into the A coil, and then the liquid line right as it comes out of the A coil.
I have a probe about 1" from the defrost probe on the outdoor condenser.
Is there another location I should put a probe(s)?
I could add one after the A coil but BEFORE the resistant heat strips.
Further, I am not even sure if there is a benefit to monitor the liquid line temp.
-Andrew
DIY hobbiest
Old 02-12-2009, 04:20 AM   #8
An old Tradesmen
Not the line temps.
The air temps.
One before the electric strip heats.
That way, if you know the entering air temp, the leaving air temp, the amount of defrost, and the CFM.
You can calculate, how much heat was removed from the house, during the defrost cycle/cycles.
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 09:05 PM
Second Furnace for dual fuel AndrewF HVAC 20 01-12-2009 07:40 PM
Add electric heat so suppliment fuel oil? arichard21 HVAC 12 01-13-2008 10:23 AM
