Tring To Find Kg Number On My Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 09-08-2010, 10:02 PM   #1
Tring to find kg number on my furnace
I am replacing my split unit over to and contained unit . And the sales person is asking for a kg nuber for the heast strip and i can't find one. How do i find this number? All i know is that it would be a nuber between 10 and 20.
JASSTEVMON is offline   Reply With Quote
Old 09-08-2010, 10:08 PM   #2
Do you mean "Self Contained" unit?
And do you KW instead of kg?
hvaclover is offline   Reply With Quote
The Following User Says Thank You to hvaclover For This Useful Post:
JASSTEVMON (09-08-2010)
Old 09-08-2010, 10:13 PM   #3
yes self contained, they told me kg, thought they might of mistakin and ment kp, but i am finding a kw on the heat strip that is in it now. i have a spilt now and changing over to a self contained
Last edited by JASSTEVMON; 09-08-2010 at 10:31 PM. Reason: did not fill like i answered my reply good enough
Old 09-09-2010, 05:35 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 134
There may be stickers with numbers on the plate the elements attach to. If all else fails do a heat loss calculation to find out how much heat you need and post it here. We can figure out how to convert that to Kw for you. You can also get a electrician to run the elements and check the amps draw and convert that to Kw.Load Calculator
Old 09-09-2010, 07:14 PM   #5
An old Tradesmen
Rewards Points: 7,814
Is this salesman, an online salesman.
Before you order it. make sure what it will cost you(weather you do it, or an electrician) to have/run a new electric line to the site that you intend to set the package unit. Along with the cost of the new disconnect, the extra duct work, lintels/or slab. rain shield. Etc.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Why can't I find a good thatch rake or pine needle rake? carl1864 Landscaping & Lawn Care 5 06-05-2011 01:01 PM
Installing furnace in a closet djlazar HVAC 10 01-23-2010 11:34 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Add-on Wood furnace billmac HVAC 3 06-18-2008 09:17 PM
