TRH7500D Wiring For Traine Weathertron With Heatpump - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2009, 09:32 PM   #1
TRH7500D wiring for Traine Weathertron with heatpump
Could you please assist me with the wiring of my new Honeywell TRH7500D thermostat which is replacing a Trane Bayside 278 thermostat?
Old wires connecting
X2
O
G
Y
R
B
T
I have a heatpump and emergency heat switch on the current thermostat.
Thank you for your assistance
Steve
swill44 is offline   Reply With Quote
Old 11-13-2009, 10:05 PM   #2
Houston204's Avatar
Rewards Points: 556
Remove power to your air handler before replacing your thermostat. Write down your existing terminal = color combination. Color codes vary.
Old = New
X2 = E
O = O/B
G = G
Y = Y
R = RC & R (Use provided jumper)
B = C
T = Tape this wire off. Your new stat will not use this thermister terminal.
Set option 170 to 7
option 190 = 0
Houston204 is offline   Reply With Quote
Old 11-13-2009, 10:24 PM   #3
Thank you very much. I apprecate it.
Steve
Old 11-14-2009, 10:25 AM   #4
Houston204's Avatar
Rewards Points: 556
I didn't see a W listed in your initial post. W = Aux.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Wiring a Honeywell ProVision TH8321U1006, upgrade from Weathertron Tstat drandersoninc HVAC 6 10-04-2009 03:20 PM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
