Transite HVAC Ducts - HVAC - DIY Chatroom Home Improvement Forum
Old 06-17-2012, 07:39 PM   #1
Transite HVAC ducts
I believe that I have two transite HVAC supply ducts that run under the slab in my living room. I have a "regular" basement under most of the house, but the living room is on a slab. They appear to be in good shape, but I would still like to stop using those ducts. We rarely use the AC and have just put a good gas buring insert in the fireplace in that room. I can shut the dampers to those ducts in the basement, but is there other/better ways to seal those ducts off? Also, will shutting off/seal those ducts screw up the air flow in the rest of the house?
Jordy is offline   Reply With Quote
Old 06-18-2012, 05:25 AM   #2
An old Tradesmen
Rewards Points: 6,500
Air flow will increase slightly. Will need to check if supply temp increases too much in heating mode. And that the system still has enough air flow when you do use the A/c.
So I looked INSIDE one of my HVAC ducts, see what I find? htabbas HVAC 4 11-22-2011 06:17 PM
Do I need to add HVAC ducts to my below grade basement rooms if my daylight basement rooms already have HVAC supplies and returns? cmgoss HVAC 1 06-29-2011 06:12 PM
DIY relocation of HVAC ducts cbrc5eric HVAC 6 05-26-2011 09:29 PM
Can you glue to HVAC Ducts tro0925 HVAC 3 03-24-2011 04:31 PM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 08:37 PM
