Is This Transformer Correct? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2010, 01:12 AM   #1
JJboy's Avatar
Is this Transformer correct?
Trane XE78/1000
This transformer is 16VAC 10VA output. I thought the lowest output would be 24VAC - 40VA
JJboy is offline   Reply With Quote
Old 12-19-2010, 06:20 AM   #2
An old Tradesmen
Rewards Points: 7,414
Depends what it is running. Its not running the furnace.
Old 12-19-2010, 07:37 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,318
Take 1 wire off and then go outside and press your doorbell button and C if it works.
Old 12-19-2010, 08:40 AM   #4
An old Tradesmen
Go out side and se if your door bell works with it connected. And then check it again after removing the wire.
Old 12-19-2010, 11:47 AM   #5
JJboy's Avatar
Interesting test. When I pressed the doorbell the Fan Motor started to running.
Unable to find out how to wire a dimmable light transformer Maleko Electrical 9 02-07-2010 01:07 AM
transformer questions Steelhead Electrical 8 10-25-2009 08:39 PM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
Comfortmaker RPJ - Bad Transformer? olgranddad HVAC 2 12-26-2008 11:10 AM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 08:21 PM
