Old 09-13-2009, 12:43 AM   #1
Trane Z Wave Thermostat Installation
I'm pretty good at wiring and testing circuitry. This is one of the ones that has gotten me obsessed. I've been installing Z Wave devices in my home, with very little problem and have been trying to install a Trane TZEMT400AB32MAA, so I can check and change my thermostat from my cellphone. I had been using a Honeywell battery powered thermostat, it could be model 9732. It worked fine and I've had to revert to it during this process. The Trane unit requires 24VAC, so I had to add a common from the air handler. I've installed everything according to instructions, and have 28VAC where it is supposed to be, between the C and the RH-RC, plus I have a W, a G and a Y going to the air handler. The problem is that I attach the unit to its backplate and I get nothing. No LCDs, no Light. I called the manufacturer and they said that if I put 24VAC to the C and the RC-RH pins I should see LDC reading. I tried it, with alligator clips and got nothing. So I returned the unit this week, and happily got the new one in the mail today. The result is the same. Do you have any ideas? If you're wondering, the Z Wave function does not come into play until I get the thing installed and working manually.
I saw somewhere on the web a note about checking the current on the 24VAC. This furnace actually has two air handlers ganged together and two transformers. I went to Radio Shack and bought a 28 volt light and socket to use as a load to check for current flow. When I tested it, I didn't see any, but as I write this I checked the continuity of the light and see that it is open. I don't think I had enough resistance, and the thing was burnt out before I got back to the thermostat. The mystery continues.
Thanks,
TommyTelephone
TommyTelephone is offline   Reply With Quote
Old 09-13-2009, 04:51 AM   #2
An old Tradesmen
Make sure your using the common of the transformer your hot is coming from.
help with installation of Honeywell RTH8500 thermostat dg xy HVAC 19 07-28-2009 01:25 PM
Help with Trane HVAC Thermostat taylorjo32327 HVAC 0 07-22-2009 02:31 PM
Bryant Evolution Thermostat: Installation & Programming NickE1963 HVAC 6 01-27-2009 04:57 PM
help with installation of Honeywell RTH8500 thermostat dg xy Electrical 2 11-13-2008 08:03 PM
Thermostat Installation help helpless handyman HVAC 16 11-21-2006 09:31 PM
