Trane XV95 Furnace Cfm Levels? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-26-2009, 10:44 PM   #1
Trane XV95 furnace cfm levels?
Greetings.
I'm planning to get a Trane XV95 furnace, but I'd like to know basically what the cfm levels will be for the 1st stage, & the 2nd stage.
I'm sure this will vary per setup I suppose. And per Model too.
Isn't Tranes smallest unit at 60,000 BTU's for this Model? That's probably the size I'll be using then.
My home is just over 1400 sq. ft. & is a ranch style,
Will be using a EAC (Electronic Air Cleaner). Which has been said to have a minnimum airflow need at 1000 cfm
Last edited by WhatWasThat?; 04-27-2009 at 07:10 PM. Reason: Added that EAC has minimum airflow need.
WhatWasThat? is offline   Reply With Quote
Old 04-27-2009, 08:27 PM   #2
Rewards Points: 150
Originally Posted by WhatWasThat? View Post
Greetings.
Looks like you answered your own question . Actually the pdf has the cfm data you are looking for..
The xv95 pdf is to large to post on this site but you can find it in post 32 at the HVAC-Talk link attached. It suggests that the 60k btu is the smallest xv95.
http://hvac-talk.com/vbb/showthread.php?t=263402&page=3
(My house is 2800 sq ft and I heated it all winter (in NJ) locked in 1st stage which is ~62,000 btu's according to my gas flow.)
Key1
Key1
In the land of the blind....the man with one eye is king....
key1cc is offline   Reply With Quote
Old 04-27-2009, 09:27 PM   #3
Originally Posted by key1cc View Post
Looks like you answered your own question . Actually the pdf has the cfm data you are looking for...
The xv95 pdf is to large to post on this site but you can find it in post 32 at the HVAC-Talk link attached....
Key1
Much obliged indeed ... I will download this & check it out.
Old 04-27-2009, 09:45 PM   #4
You Da Man!
This is what I was looking for.
Is this considered an Install manual?
So glad you had this doc.
Actually I thought I had downloaded this previously from the web, but couldn't locate it for the life of me (& life is precious wouldn't you know ).
Old 04-27-2009, 10:18 PM   #5
An old Tradesmen
Rewards Points: 6,860
I knew I didn't delete that PDF quick enough. LOL
Old 04-27-2009, 10:21 PM   #6
That is funny ... but you can rest assured this dude isn't into diy anyway, ha .
Old 04-28-2009, 04:56 AM   #7
An old Tradesmen
LOL...
Its still there for all those that want it.
You might need it when a tech has to comes out to service your furnace.
Old 04-28-2009, 06:48 AM   #8
Rewards Points: 150
That's why I needed it in the first place...
Because pro nate certified techs did such a great job installing my furnace ....LOL
Key1
Old 04-28-2009, 06:54 AM   #9
An old Tradesmen
Key1
LOL...
NATE cert don't mean much.
Other then:
Someone paid to take a written test.
A company was hoping to make more money from advertising that they have NATE certified techs.
And NATE gets to make more money when someone pays to renew their certs every 5 years.
Honeywell stat wiring w/ Trane furnace JaePee HVAC 7 01-18-2009 06:50 AM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Lennox G61MPV vs. Trane XV95 Furnace CompuPsych HVAC 2 11-21-2008 08:20 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
