Trane Xv90 Fault Code - HVAC - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 10:11 AM   #1
trane xv90 Fault code
I've read the posts. I have a 5-6 yr old XV90. I am getting 2 fault codes; 2 red blinks for system lock out & 3 red blinks for a pressure switch fault. I've reset the system & cleaned the flame sensors. The system fault is cleared but the pressure fault remains. Any ideas? Thanks
Joe Sol is offline   Reply With Quote
Old 02-28-2011, 10:58 AM   #2
JJboy's Avatar
Check your pressure valve, Aux fan and exhaust pipe.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 02-28-2011, 02:39 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
check the drain hose at the bottom of the inducer and remove and clean the condensate trap
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Canadian Electrical Code Question flemingetq Electrical 4 11-25-2010 10:42 AM
Bryant Fault Code 31 - Just Changed Air Filter! matimo312 HVAC 12 11-21-2010 11:06 PM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 08:52 AM
Trane XE 80 Code 2 Help bigbb1960 HVAC 1 01-09-2009 10:56 AM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 11:06 AM
