Trane XV80 No Flashing Light - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-28-2009, 09:18 AM   #16
GC/Master Plumber/Mech
Rewards Points: 560
I would just replace the stat.
The stat only needs to be for a single heat and cool.
Old 02-28-2009, 11:05 AM   #17
So I can use this lux Pro stat and run the wiring like you said earlier and check the manual to make sure the ppins are set for dual stage furnace single stage stat?
KabbyBarty is offline   Reply With Quote
Old 02-28-2009, 03:20 PM   #18
Rewards Points: 560
From the pic you posted it appear that necessary adjustment to the board are already made for the use of a single heat stat
So, I wouldn't mess with any connections at the furnace. Just match the wires off the old stat to the new stat.
Trane xv80 install draft exhaust wires on furnace biggiant HVAC 5 02-10-2009 07:50 PM
Trane XV80 - low speed fan not working oregondean HVAC 4 01-12-2009 01:46 PM
Trane xv80 furnace blower not working jim2138 HVAC 2 03-22-2008 05:55 PM
Trane 80xl, 3 flashes error light - draft pressure problem, help? Xsta HVAC 1 10-14-2007 09:20 PM
Glow plug warning light is flashing spidenkin Automotive Repairs 1 07-18-2007 04:41 PM
