| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Make a Fireplace More Efficient
by eHow.com
The efficiency of a fireplace depends on several factors. Though the design is certainly important, it isn't the only thing to consider. Adding components and performing routine maintenance are critical to maximizing efficiency. No matter what type of... Read More »
How to Heat an Ice Fishing House
by eHow.com
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
How to Clean Your Chimney
by eHow.com
There is nothing quite like a crackling fire in the fireplace on a cold winter day. As wonderful as this may sound, this lovely fire can turn deadly if your chimney is not properly maintained. Every chimney should be cleaned at least once a year to... Read More »
How to Winterize a Mobile Home
by eHow.com
If you're living in a mobile home and facing your first winter, you may not be aware how difficult it can be to keep a mobile home warm. Taking the proper steps to winterize your mobile home cannot only help keep you warm, but keep your heating bills... Read More »
Common Furnace Problems
by Shawn Kenny
The most common reason for furnace failure is a furnace filter that is dirty because the filter should be changed every three months. Discover how cold weather and snow can cause furnace problems with help from a plumber and HVAC tech in this free video... Read More »
