Trane xv80 furnace blower not working
I believe you have a variable speed furnace..if you have your fan switch turned in the on position, it should be running. If it doesn't , there are alot of things that could be wrong...the motor is bad, the motor control is bad etc. There are no separate fuses for only the motor. Sorry to say, but you should probably call in a pro. Variable speed motors copntrols, especially Trane can be pretty pricey. Good luck. Refer to your owners manual for error code diagnosis. Wish I could be of more help.
